Ignition coil
Loghan
Canada
1997 ram 1500 5.2L
Truck not starting
When I put a spark plug on the wire coming off the ignition coil and ground it no spark....
There is 12v on both the constant power and also on the trigger/signal wire is that normal?
pacofortacos
If you have 12 volt on both terminals of the coil that is not normal while cranking or running.
If it is just sitting there, you might read battery voltage on both sides.
L
Loghan
Canada
While just sitting there is 12v on both sides.
When I crank it I only have a multimeter to test it and I do not think it reads fast enough to read the signal.
So question is....
When key is off or in on position should I have 12v on both sides of the plug?
L
Loghan
Canada
Anything else why no spark from coil?
Dan98
Try a different computer! If it all the sudden lost spark but fuel pump probably still works and obviously turns over then computer quit. Coil pickup maybe bad.
Sent from my SM-J260A using Tapatalk
gville35
