command start
  1. K
    Command start and remote unlock issues
    Got an 09 ram 1500 5.7l. My command start will not work and the fobs will not unlock or lock the 4 doors. When I use the physical key to unlock door instead of the fob the factory alarm sounds till I put the fob in the ignition. This is factory installed command start no other electronics...
  2. E
    Weird keyfob/command start issues. Help!
    Hello, I posted about weird issues I was having with my 19 ram 1500 about a month or two ago. FCA wanted me to take a video of the issues so I did and thought I'd post it here hoping someone else has experienced the same thing and knows the cause/fix. Here is the video.. sorry it's a bit long...
  3. R
    Weird remote start problem
    The remote start doesn't work unless I take it completely out of the casing and push the button right on the electrical board. The lock and unlock buttons work fine without dismantling the remote just the remote start doesn't work. Does this make any sense to anyone?
Reticle918
