differenial fluid
  1. SalvageRam
    2012 5.7l hemi Front diff leak...not sure of the cause
    My 2012 Ram 1500 5.7 liter Hemi has a front differential leak, and I need help pinpointing where exactly it's coming from. In the pictures provided, you can see that there is a small and slow leak on the front diff where it connects to this second half of the front diff. Not sure what its called...
  2. D
    Hello I’m new this area and wanted to start servicing my own truck
    Hello I’m new this area and wanted to start servicing my own truck which is an 4x4 andespecially the differentials front and back including the transfer. The truck is coming up on 63,000 miles so I would like to service it sooner rather than later. My back ratio is 3.92 for my front I have no...
  3. Rob McClure
    rear diff fluid question
    hey yall, my 1500 has the 3.21 rear gears ( i know ,lol ) without limited slip , I talked to ram to verify that it didn't have limited slip and they confirmed and the y sent me the build sheet which is pretty cool , my question is , I have Amsoil 75w/140 fluid am I good to run that in the diff ?
  4. M
    Issues finding what differential I have. 2014 - Tradesman - 2wd - 3.6L
    If this is in the wrong subforum I am sorry. I looked at a ton of posts on here with links to lookup vins for window sticker and build sheets. NONE of them work for my vin. I just need to know what diff I have and if it is limited slip or not so I can change my fluid. VIN- 1C6RR6FG6ES285861...
  5. H
    Transmission fluid and rear differential fluid change
    So my 2014 Ram 1500 SLT 5.7 Hemi has 195k miles and I am deciding to change the transmission fluid and differential fluid as well since I am not sure how long since they've been changed. I've never done either change before so I am asking for advice as well as what are the correct type of fluids...
  6. El Guapo Phil
    Differential Fluid Change Question
    I live in Belize, Central America. There is only two seasons here, hot and occasional rain, and hot and rainy (June through October - Hurricane season). I use the 4x4 function almost daily to go up a 200 foot hill where the house sits. Up is 4x4 and down is 2x4. No towing involved. My 2016...
