drain plug
  1. expressreg
    Need Help Removing Radiator Drain Plug
    I have 2017 ram 5.7 rcsb and the drain plug is just spinning in place i tried pulling it out and nothing pls help
  2. C
    Oil drain plug can’t come off
    So, I have a 2011 ram with the 4.7 engine. I had the engine swapped out a couple months ago with what I was told was from another ram truck. So now today I go to change the oil, only to see that the frame is right below the drain plug. So I wasn’t able to use a socket and used a wrench to...
  3. Orange whip
    radiator drain plug (S) 4.7 2005 ram do these trucks have 2 drain plugs, I know of the one on driver side
    I have a 4.7 2005 ram 1500 - I know of one radiator drain on driver side low , is there another one on passenger side below the overflow?
