Need Help Removing Radiator Drain Plug
expressreg
I have 2017 ram 5.7 rcsb and the drain plug is just spinning in place i tried pulling it out and nothing pls help
expressreg
expressreg
turns out this my coolant level from the resavoir, it might be because theres no coolant
TC
Central TX
The plug is not designed to pull completly out, just a couple turns and the coolant should begin to discharge. However, if continued turning the plug should come out. Are you using a hex bolt or socket to remove? If memory serves me correctly, a 16mm socket fits over the plug.
expressreg
expressreg
i had the right hex bolt but i was doing it wrong, i was supposed to pull and turn the ratchet while doing it.
But coolant drain was a success
