fan speed
  1. M
    A/C only works with truck in movement
    2018 Ram 2500 6.7L Cummins Turbo Diesel The problem is that when the truck is not moving (for example, stopped at a traffic light or idling at home), the air conditioning does not work, and many times the compressor releases refrigerant gas, as if due to high temperature or pressure. (I know it...
  2. T
    2008 Ram heater fan issues, even more confused after reading on the subject.
    Hello everyone, new guy with an old problem. The heater fan was working intermittently on my 2008 Ram. I was letting it go until the sub zero temps moved out. I would have to hit the heater box to get the fan moving again. Today (50 degrees temp fortunately) the fan finally stopped so I removed...
