mario_rubio
- Feb 16, 2025
- 4
- 0
- Location
- Miami
- 208
- 6.7L Cummins Turbo Diesel
2018 Ram 2500 6.7L Cummins Turbo Diesel
The problem is that when the truck is not moving (for example, stopped at a traffic light or idling at home), the air conditioning does not work, and many times the compressor releases refrigerant gas, as if due to high temperature or pressure. (I know it is normal for it to release gas due to temperature or excess refrigerant.)
I have already replaced the fan clutch, checked the high and low fan relays, and they are fine. I also checked the harness from the fuse box to the fan, and it is fine. I confirmed that the relays are receiving 12V. I also checked the fuses, and they are all good.
The A/C only works properly when the truck is in motion.
I’ve noticed that the fan is always on, but it does not seem to increase speed even when I turn on the A/C. It seems like the high-speed function of the fan, which should activate under certain conditions, is not engaging. I initially thought it was the fan clutch and replaced it, but that was not the issue.
Does anyone have any advice on what to check or what to do next?
Thank you in advance
[email protected]
[email protected]
