fifth wheel
  1. L
    5th Wheel prep Install - 2022 3500
    I am installing the 5th wheel prep kit (Part # 82215837AC). I didnt realize it said to remove 4 bolts connecting the box to the frame to install the pucks. Has anyone done this before? If so how did you do it? Can you confirm this is the correct bolt?
  2. M
    Need Advice - 2020 Ram 2500 & Towing 5th Wheel Toy Hauler
    Long post but I'm kind of at a loss right now. Truck is a 2500 Laramie 6.4L V8 with standard/short box and 3.73 axle ratio. VIN states: Towing capacity is 14,080 lbs; Payload capacity is 3,014 lbs; GVWR is 10,000 lbs. Right now I'm towing a bumper pull 2012 Keystone Cougar 31SQB. TT is about 36...
  3. krakaman24
    4th gen 2500 5th wheel prep kit
    Looking for the 4th gen 2500 OEM prep kit for a fifth wheel. AKA the puck system or under bed mounts. It's Mopar part number 82215838AB.
  4. Motorman001
    RV Electrical Plug Question
    My truck is a 2015 RAM 3500 DRW Cummins with dual 220A alternators. My question concerns what is commonly referred to as the 12V power or auxiliary charging connection on the 7-way RV receptacle. This terminal is always hot, even when my truck is parked and turned off. I suspect that is...
  5. tourrider
    Found my 5th Wheel Toy Hauler!
    I drove to Buffalo to buy it this weekend. Kind of ironic to buy my RV during the seasons first major lake effect snow event :) Didn't bother me, I grew up in that area. It's a lightly used 2016 Grand Design 350M. I'll be towing it home on the 24th of this month. Exciting stuff.
