hardwire lockers
  1. continuecrushing
    Locker Bypass Installed: Abel Components
    If you guys are bothered by the function of your lockers (takes forever to engage/want to use them in 4hi or 2wd) and you want to keep the factory switch, the Abel Components bypass is what you need. I installed mine a while back, it's pretty easy. There's more info on a different forum, but...
brixten
