heat control
  1. N
    Heater Ticking Noise
    Hey, Very recently, when my heat is turned on there is a ticking sound on the passenger side of the vehicle. It obviously speeds up and slows down when you adjust the fan level. I started hearing it about a week ago, but it wasn't as loud as it has become. Not sure what this is a result of...
  2. L
    Luke warm driver side, hot passenger side
    Got my 2013 Ram 1500 4.7l having HVAC issues. It’s starting to get cold here in Texas and have already had some weather get to 30 degrees recently. Main issue I’m facing with HVAC is that when I put heater all the way hot, with engine at operating temp, passenger side is hot but driver side is...
  3. UncleRooskie
    2014 Sport
    Ran into a problem with my climate control, only on drivers side. When adjusting my heat the temperature will drop from hi to low on its own, when I turn it back to high it will again drop to low. Sometimes the buttons won’t work and I have to adjust from the 8.4 screen only to have it drop to...
  4. D
    Diagnosing problems with the HVAC box
    I am new to this forum please let me know if I'm posting this in the wrong place or if there is a better thread. I've been having a problem with my hvac only blowing down at the feet, sometimes it works normally but most of the time it doesn't. And recently I'm having the same problem with...
  5. F
    All of a sudden no heat
    Hey guys 2014 outdoorsmen 6.4 hemi 2500, I had heat the day before I came out to go to work and started the truck to warm up. I noticed going down the interstate that the defrost was on but was blowing cool air , changed to the feet same result. 30 min drive coolant temp 195 no heat. I took it...
  6. M
    Only heat
    The heat in my truck won't go it cool or cold I bought a new blend door aviator and it only moves when I turn the truck on it cycles cold to got and then nothing the actuator in the glove box is the one with the issue please tell me what it do I have heat but nothing else
  7. S
    No heat then full heat
    My 09 is all cold UNTIL I turn heal control up to down to up, etc. then I hear a 'door slam' then I have full heat. Seem to not get any variation using control. Full cold followed by full heat. No idea if bad door or what??? Help please.
