led turn signal
  1. ColbyAK
    LED Turn Signals '09-'12
    I have the OBD Link MX+ and using Alpha OBD software with it on my '11 Ram 2500, i can't seem to find an option to enable LED turn signals for the front and back to disable hyperflash. I installed switchbacks in the front and regular white LEDs in the tail lights. Has anyone figured this out, or...
  2. Underground Lighting
    Hyper Flash Turn signal Solution Plug and Play Resistors
    Hi Everyone, We have had a lot of customers asking us for a plug and play solution for hyper flash. Those of you that may not know what hyper flash is, it's when you change your turn single bulb to led and your light flashes fast and your dash indicator flashes fast as well. There was always a...
