lift level
  1. D
    Size of lift?
    i previously asked the size of my life but I have the measurements now I measured from the exact center of my wheel to fender like it shows in the picture it was 24.5 to 25 inches exactly i thought i was 25 but my tape was down a bit more had to put it exactly in the middle so (24.5 for the...
  2. D
    Asking what size lift do I have pls? rear look higher than the front ? Bough truck from Texas it’s a lonestar edition it’s the gray truck on the pic
    Asking you guys the experts for help asking what size lift or leveling kit does this truck have it’s currently sitting on 31s both rear and front and wondering because the rear looks higher than front sometimes which is the opposite of squatted trucks just bought the truck a 2010 lonestar...
  3. M
    5100 RHA Headaches
    So I put the Bilstein's on back in 2020 and it's been headaches ever since. Took caution to ensure an alignment was done after any adjustments to get the truck where I want it. Currently it's at the TRX/17.5mm setting, which is the first up from stock. I have a slight lean to the rear I'd like...
  4. Ram7081
    Alignment seems ok after Zone UCA install?
    I have included pics from previous alignment after installing 2" Vertex coil overs and now after installing Zone UCA. Done by two different shops. I thought it would be better. Did I expect to much? First one - Current Second one - Previous
