mds camshaft
  1. 4d6n2
    Cylinder Misfire Led to Full Cam/MDS Delete Build + Suspension & Audio Overhaul
    What’s up yall — I’ve got a 2014 Ram 1500 5.7 HEMI with 144k miles, and I figured it was finally time to post up after diving deep into a full-on performance and refresh build. It started a couple months ago when I got a check engine light. The truck started running rough, struggling to...
  2. D
    Misfire Codes After Engine Swap
    I got a 2010 Dodge Ram at an Auction Last Year. A month into driving it the engine seized. I put in another engine that was swapped out because of a bad cam, is what I was told. I put in my old cam in after inspecting it. MDS lifers were still good so I put them in the "new" engine too. I had...
  3. 14Deebo
    OEM 5.7 HEMI MDS Camshaft and lifters
    Selling a stock MDS Camshaft and lifter set with trays from my 5.7 2014 Ram 1500. One of the lifters is bad, but I am not sure which one, so you'll have to check them to be sure. Cam and lifters have 53k miles on them and all appear to be in great condition (obviously other than the one bad...
