misfire cam lifter
  1. 4d6n2
    Cylinder Misfire Led to Full Cam/MDS Delete Build + Suspension & Audio Overhaul
    What’s up yall — I’ve got a 2014 Ram 1500 5.7 HEMI with 144k miles, and I figured it was finally time to post up after diving deep into a full-on performance and refresh build. It started a couple months ago when I got a check engine light. The truck started running rough, struggling to...
  2. I
    Dealer recommends engine replacement for @63k miles
    Had the hemi tick the past month. Had a misfire code on one of the cylinders. They said one of the rods are likely bent. Dealership recommends a cam and lifter replacement for 10k or engine replacement for 14k on my 2015 ram v8 with 63000 miles on it. Might just pay the diagnostic and take to...
  3. J
    Any and all advice welcomed …
    Greeting fellas Ran across this forum multiple times (unfortunately and thankfully) here recently. Just looking for tips and advice, it will be greatly appreciated. I have searched multiple threads on here and gathered great information on how to move forward so TIA for that. Here’s the back...
  4. T
    Misfiring and shaking 2011 Hemi 5.7
    My 2011 Laramie 5.7 Hemi is Misfiring. Firestone first replaced all spark plugs, now says that i need to replace lifters?
  5. GlennB
    2013 Hemi Misfire Cylinder 2
    I'm the original owner of a 2013 Bighorn which currently has 108K miles on it. It's been used as a passenger car since Day 1 - never saw a load in it's bed beyond the annual Christmas tree. Documented oil changes every 3,500-4,000 miles, plugs changed at 50K miles, trans fluid changed every 50K...
