mobil 1
  1. Rod Knock
    0W-40 in 5.7 HEMI and 6.4 HEMI
    How many of you guys are running Castrol EDGE Euro 0W-40 or Mobil 1 FS 0W-40 in your HEMI 5.7? And how many of you are running one of these two fine motor oils in your 6.4 HEMI. Please comment and spare no details. How do you like it, did any of the two quiet your engine, and for how many miles...
  2. Rod Knock
    Red Line Synthetic Oil 0W-40 - has anyone tried it in the 5.7 HEMI?
    Currently, I'm running Mobil 1 FS 0W-40 in my 2016 Ram 1500 Big Horn with the 5.7 HEMI. I'm using a Purolator BOSS PBL12222 oil filter. The truck runs great and other than the injector tick noise that's characteristic to these engines I don't have any issues with it. I actually listened to the...
  3. Motor Head
    Rear Differential Fluid Change (AAM 11.5)
    For those who are looking to get their rear differential fluid changed out, here is my tutorial video I made of the process I used. Overall, very simple process, with minimal amount of tools. I threw in Mobil 1 75W-90 to suffice, until I can throw in some amsoil for the long haul. After draining...
  4. Motor Head
    How-To Front Differential Fluid Change
    If you have ever re-geared any vehicle in the past, you know that after its first 500 miles, you need to change out the fluid. After using my 4x4 for a bit, and after doing a rear diff fluid change, I opted to flush the fluid out for the front diff as well. Will your truck survive after 30-60k...
  5. Motor Head
    DIY Greasing Front Drive Shaft Fitting
    As the title states, I show you how I greased my front drive shaft fitting on my 2018 Ram 2500. The truck finally hit enough miles to require its first mandated service which included a tire rotation, topping of DEF, inspecting the suspension/front end, and lubricating the front drive shaft...
jimn
