no spark
  1. 9
    5.2 pickup coil signal issues
    So for four months I have been battling this truck 1996 dodge ram 1500 5.2 automatic. I bought it with intermittent manufacturer code which I believe was the crank sensor. It died and a swap fixed the issue. Then about three months later same code came up. Changed the crank again and then...
  2. xevrek
    96 5.9 v8 4x4 no spark
    So I’ve been hunting down this problem for awhile now and I’ve come up short. My truck just lost spark out of nowhere and I’ve replaced everything that I could think of coil, plugs, wires, dizzy cap, rotor, camshaft sensor, crankshaft sensor. Am I missing anything
  3. G
    Crank, no start & no spark - ASD relay not making connection
    I have a 2003 Ram 2500 5.7l hemi that will crank but not start. For the last couple months it has been hard to start, I have to crank it for 5-10 seconds before it fires up. I thought the CPS was going out so when it wouldn’t start at all I replaced the CPS and nothing changed. I tested for...
  4. Don Evjen
    2002 5.9L got no spark , checked everything I can think of
    I parked my truck a week ago in my driveway now , wont start , turns over good got no spark , all fuses and relays good , new battery unplugged and removed fuse box and ECU , cleaned connectors and checked tested crank sensor , good tested coil , good still nothing , no spark any ideas ?
  5. rrb6699
    1996 5.2 No Start but cranks fine
    I bought the truck and it ran fine but, noticed the water pump was leaking and red atv on the heater tube. replaced the water pump and fan clutch and put everything back together. Went smoothly so I thought. Went to crank it to test it and only get crank but no spark at the plug. I can't...
gville35
