2002 5.9L got no spark , checked everything I can think of
Don Evjen
Edmonton Alberta Canada
I parked my truck a week ago in my driveway
now , wont start , turns over good
got no spark , all fuses and relays good , new battery
unplugged and removed fuse box and ECU , cleaned connectors and checked
tested crank sensor , good
tested coil , good
still nothing , no spark
any ideas ?
RodeoRam
Supporting Member Air Force
North Carolina
Hemi 5.7 2500 CC
Sounds like it's somewhere around the distributor. Is the distributor getting spark from the coil?
MikeT
Chino Valley, AZ
CTD
Did you do anything to your truck in the week it was parked? Like make any changes to anything.
Mike
LordZarkon
Kansas
Just saw your post, I was wondering what the solution turned out to be for your no-start problem. I know Chrysler has 2 sensors, one at the cam, another at the crank, and if either goes out, it will crank but not start.
