oil control module
  1. A
    5.7 Hemi, 2011 MAP Sensor Question
    Is the MAP sensor supposed to wobble after it is fully engaged in bore after the 1/4 turn? I've been chasing a no CEL RPM fluctuation and it appears to be associated with the MAP sensor. I cleaned it and put some grease around the Oring and it ran like a champ for about 100 miles, then started...
  2. jlyalls
    2012 Ram 5.7L Replaced OCM but code still shows up after unhooking battery
    Hey guys, I started getting a check engine light and had Autozone scan for me and it brought up certain codes that suggested the OCM (Oil control module) needed to be replaced. The truck has roughly 134,000 miles. So I removed the intake manifold and replaced the OCM with a newer one. You...
