oil temp sensor
  1. S
    RAM1500 2017 HEMI - water leaking by the oil temperature sensor
    Hello, I think I already know the answer what will follow, but did anyone already seen this? Water is leaking by the threads of oil temperature sensor on oil filter housing (oil cooling route). I suspect this part of block is cracked. I don't think this can be repaired without replacing lower...
  2. J
    292 Oil Temp??
    Hey guys I was just cruising and my oil temp was at 292° F and my oil change light came flashing on. I just did the oil just under 3,000 miles ago. Outside air temp was 30° F. Water temp was slightly above half on the gauge. Oil pressure was reading 3/4 on the gauge. I’m at 130,000 miles and...
