remote keyless entry
  1. B
    2014 dodge ram 1500 tradesman
    Hello! I have a 2014 dodge ram 1500 tradesman attempting to add remote start. I have alpha obd and obdlink, I have used that to program a key and it works as it should, upon reading the fourm some mentioned I need a 1k ohm resistor to ground the wire for the hood latch, which I had one handy and...
  2. M
    Problems with Remote-Start/Unlocking/Locking
    So recently, about 3-4 months now, my remote- start doesn't work. When if first started going out I could spam the button on my jey fob and it would eventually work but now it doesn't at all. In addition to this, sometimes, and this is on and off now, I cannot unlock or lock the truck. It takes...
  3. Sking80
    OEM Remote Start 4th gen $150 on FB Marketplace
    Ran across this on Facebook Marketplace It the OEM Remote Start for 4th Gen $150 https://www.facebook.com/marketplace/item/228209222730046/
  4. Athlium
    Adding Remote Keyless Entry (keyfob lock/unlock) DIY w/ ALFA
    Wanted to add informed post with directions through my personal experiance. I recently purchased an 2018 1500 Tradesman with tip keys / Sentry keys. Which meant no remote lock/unlock keyfob. Here are the steps to get remote fob added for your 4th gen. all following were done with Alfaodb...
  5. A
    RKE receiver location
    Would someone tell me where the receiver for the Remote Keyless Entry (RKE) receiver module is located? I have searched all over and can't find the info. I would like to unplug it hoping to reset it and se if that will get my key fobs working again.
  6. B
    2013 2500 remote start
    So I tried, to research this, so I did use my alphaodb and turned my remote start, not working.. so looking into this more, do I need the hood latch with the switch, in order for it to work. Or any other things.. Thanks
  7. NoFlyZone
    Problem: '06 RAM 2500 Remote Keyless Entry Disengaged
    '06 RAM 2500 5.9L Laramie, where the power door locks with keyless entry all stop functioning, and the chime sounds when the engine is turned off once the door is opened. I reset the power door locks so they once again work by following manual instructions by turning key to on/off 4 times, then...
