ring gear
  1. DizzyFranco
    What cause my ring gear wear to look this way?
    is there anything useful that can be learned from this wear pattern? if you are experienced with differentials, can you tell me what caused it? backlash too much or not enough? pinion depth? btw its a chrysler 9.25 axle side adjusters and i believe the pinion has crush sleeve. 96 5.9L v8 4x4
