sensor problems
  1. L
    2013 Ram 1500 - Rear air suspension sensors
    Rear air suspension sensor data inverted! LF:90mm RF:68 LR:-47 RR:-41 Fender height= Fronts:39” Rears:37” Currently the truck is stuck in off-road 1, initially the trucks code weren’t showing sensor errors it was showing error:U0422 and would time to time allow you to set the ride height. I...
  2. T
    suspension air bag sensor issue
    I have a 2017 Ram and recently had a leveling kit installed. My air bag suspension sensors keep popping off and the warning light keeps coming on. The dealer is trying to tell me that the sensors are now over extended and I need to get an extension for them. Do they even make such a part? I...
  3. B
    PW 2015: Petrol filter /sensor + tank sensor + horn
    Hi together, some questions to you which could solve my problems with my PW 2015 6.4L: Is it right that the PW 2015 6.4L has only a petrol filter directly on the pump, which is mounted in the tank? Does it also have a petrol pressure sensor? Where is it located, because I can't find any...
Bob Templeman
