service electronic brake system
  1. C
    2013 ram 1500 service end message and traction control light
    I have a 2013 ram 1500 with the 5.7 hemi. When I start the truck I get a “service electronic brake system” message. The traction control light is also on and my cruise control does not turn on. Can anyone give me some direction on where to start diagnosing this issue or has anyone had similar...
  2. oldmitch
    Hydraulic ram-assist steering
    I just finished installing my steering assist kit. Pretty straight forward. Although I will point out that if you're not paying attention *points at myself* it's REAL easy to cover the world in power steering fluid, when you're bleeding the system. Also, during the bleeding process, you need to...
  3. A
    2018 Ram 4x4 diesel - "service anti-lock brake system"
    I have a relatively new 2018 Ram 3500 4x4 with a 6.7l diesel. This morning while driving the truck went over a bridge expander bump and now I am getting two errors: 1) Service anti-lock braking system with the ABS light on; 2) Service electronic brake system with the traction control light lit...
  4. L
    service electronic brake system message
    I had this message in the main display along with cruise control being disabled. (2013 Outdoorsman 4WD) Just for other members information this turned out to be caused by the steering being out of alignment. Apparently if the alignment is sufficiently 'out' it will cause this error. So the fix...
