service electronic brake system message
loopless
I had this message in the main display along with cruise control being disabled. (2013 Outdoorsman 4WD)
Just for other members information this turned out to be caused by the steering being out of alignment. Apparently if the alignment is sufficiently 'out' it will cause this error. So the fix was really quite straightforward.
Covet66
Keswick Ontario canada
Same message and symptoms for my 2015 the other days, was a faulty speed sensor on passenger front wheel bearing- it was failing.
BJSwizzle
Edmonton Alberta Canada
2019 1500 Sport
5.7L
I just had 4” lift done
hmmmm I just put in a 4” lift today, going to take it in a get a wheel alignment tomorrow, just had this light come on, I hope it goes away once it gets aligned
JohnnyMac
SouthWest Washington
2018 1500 Laramie / 2024 3500 MegaCab Laramie
3.0 EcoBurner / 6.7 Cummins HO
Mine did exactly this last week. I installed a 4" lift and on my drive into the alignment shop I got the service brakes error code. I figured a screwed something up. After the alignment was done, I decided to pop over to the Ram dealer and after getting a couple blocks from the alignment shop the light cleared and hasn't returned yet.
