shifter park
  1. R
    2011 2500 won’t shift out of park. At a loss.
    Hi. New here. Been scouring the forums for a solution to my exact problem To no avail. the truck is a 2011 ram 2500 diesel with a column shifter. The shift lever solenoid will not release on its own when I step on the brake pedal. the only way I can shift it out of park is if I use the...
