starting problems
  1. snapontech
    Need some help with 2007 to 2006 dodge ram 3500 cummins wire harness swap on hvac i/p harness
    I ended up with two different piles of junk to make it sound nicely. The 2007 had a blown motor and the 2006 did not. Because the interior on the 2007 was much better I swapped everything. Seats, carpet instrument panel, harness ect. Differences are the 06 has a power back window 07 defrost. 06...
  2. B
    2024 Ram 2500 6.7 cold starting questions
    in the morning time it can be cold and some mornings below freezing my truck is brand new with just 1800 miles on it push button start some mornings it just starts as soon as the button is pressed and other mornings it counts down i know that wait to start on diesel is normal so my question is...
  3. B
    Ram 1500 long crank
    I have a 2021 ram classic 1500 5.7l, every once in a while it’ll crank for a long time before it starts. doesn’t do it at first start up of the day. generally after a short drive or if it’s been sitting in the sun for a while. It’ll crank once and then stop and when I turn the key again it’ll...
  4. T
    My truck won’t Start
    I’ve got a 1994 Ram 2500 and the lights work, battery is good, and starter is new. Recently it hasn’t started at all, won’t even turn over. After tapping the starter it began to make a loud noise that shook things whenever I tried to turn it over, it still is not starting. Any advice?
  5. C
    Starting after 15+ tries.
    I have been dealing with my 2008 Ram 1500 SLT 4.7L not starting correctly. Like the title says, I have to sit and turn the key over and over again (only get one turn out of it and its not the sound like with a dead battery) and then after what seems like forever it starts right up and runs with...
  6. Y
    2015 Ram 1500 5.7l Hemi not starting up right away
    Last year, my truck got syphoned for gas and ever since it doesn't start up when i turn the key. it takes usually 2-3 times to startup. Any idea on what the problem is or how to fix it?
  7. L
    I have a 2021 ram 1500 big horn with 5.7 e-torque. It has a long crank before it will start, the shop is unable to find anything wrong with it.
    I have a 2021 ram 1500 big horn with 5.7 e-torque. It has a long crank before it will start, the shop is unable to find anything wrong with it. They tried replacing fuel pump, but still has the same issue. Has anyone had any issues like this or know what it could be?
  8. P
    Intermittent starting
    My 09 5.7 is having intermittent starting problems. Sometimes it won't start in park so i have to throw it in nuetral and it will start. this does not happen every time. I have verified that the starter does function by jumping it out. I have also verified that the relay is working as well. I...
  9. B
    Starting problems - fuel pressure sensor/pump/filter?
    Hi together, PW 2015 6.4L 87500mls I have some problems during starting. My PW need longer than normal to start. Coils and sparg plugs are new, battery is okay. What can cause this problem? Does someone know where the fuel sensor (Pressure) and the fuel filter is located? Thanks to all...
