throttle position sensor
  1. H
    Fuel pump or wiring?
    Vehicle: 06 Dodge ram 1500 hemi 5.7 2WD Symptoms: turns over but starter seems week. Past few months, intermittent stalling issues at idle but usually only happens once per drive. Past 2 weeks, hard start, have to pump to get it to start. Now weak crank no start. NO DTCs Live data TPS...
  2. W
    Accelerator pedal position sensor. Please Help!!
    So I got this 2004 ram 1500 with the 5.7 hemi about 7 months ago. It has 172,*** miles on it. It has new plugs, wires, and coils, 3 of the 4 oxygen sensors are new, a new fuel pump. In the last month or so it has started having trouble idling and it jerks when trying to pull out from a stop...
  3. H
    2004 5.9 Cummins trying to accelerate against break pedal.
    Hi guys, I have a 2004 dodge ram 2500 5.9 that Seems to have no issues while in neutral, but when in Drive or Reverse, the truck accelerates to around 2-5mph. When I apply the brake pedal, the truck continues to try to accelerate at a low level against the brake pedal and sounds like it is...
  4. G
    2008 Ram Dash Light warnings flashing with no codes
    I have a 2008 Ram 1500 5.7 Big Horn edition. My TPM, check engine, abs, parking brake, check gauges, and tire pressure warning lights all come on at the same time and the speedometer and the tack drop down to zero. Square boxes also appear around all of the gear indicators above the mileage...
  5. D
    Throttle Positon Sensor Errors: Help!
    Hi Rammers, My '03 Ram 3500 diesel is having some problems. I got a Bully Dog tuner, but it wreaked havoc with my truck (had to replace alternator, ECM, dash dials & APPS). (It also managed to rip the cable off the clutch fan the other day, and mangle it through the blades..!) A dealer located...
  6. D
    Throttle Positon Sensor: Where to buy
    Hi Dodgers, My 2003 3500 needs a new / replacement throttle position sensor, but they're $520 from Dodge! Any ideas where I can source one (not necessarily brand new) for substantially less..? (My sensor is located underneath the driver's battery). Any suggestions greatly appreciated! Thanks - D
