timing chain
  1. D
    2015 5.7l Hemi, Which Timing Is Right? (If either)
    2015 Ram 1500 5.7 Hemi. Did a cam / lifter swap, non MDS Stock spec cam from AMS racing. Everything went in great, after setting timing ( what i thought was correct ) engine started and ran fine but Autel was reading two small misfires on cylinder 3 and 7. Thought it was pushrods misaligned but...
  2. S
    2015 5.7 (NOT) timing issue **Rebuild**
    Good afternoon all I have a 2015 5.7L that used to be a police truck. So it has some hours on it. It was running fine and then it all of a sudden had multiple cylinder misfires and a cam out of sync with crank code. Changed all the plugs and coils and put a new cam position sensor in. Cam...
  3. B
    Worth replacing timing belt while changing water pump?
    My truck has 170k miles and my water pump is leaking. I've read a lot of conflicting advice about changing the timing chain. Some people say change it while your there and other people say not to touch it because timing chains are good for the lifetime of the engine. I was wondering what y'all...
  4. B
    2019 1500 BigHorn hemi won’t idle
    I had a cam shaft that eroded and was misfiring. after replacing the cam, lifters, and the timing chain I had gotten the misfire to go away. started it up and it had some obvious issues (Rough idle, sputtering rpm, died after a few seconds). I assumed I had made a timing mistake so I took the...
  5. C
    Replaced timing chain now crank backfire with no start
    I have a 2009 dodge ram 1500 with 4.7 liter and it was stolen a call couple months ago and when I got it back it barely ran when it did it was super super rough and wouldn't idle or stay running without pumping gas pedal I replaced throttle body, map sensor,camshaft position sensor and timing...
  6. M
    2009 4.7 Timing issue
    Hello everyone, I just replaced the timing chain on my 4.7 1500. I pulled the pins and cranked it around a couple times but the chain is still pretty lose on the bottom portion of the chain. Just wondering if this is common or if there is something wrong that I did that anyone can think of of...
  7. R
    Loose timing chain?
    My 03 Ram 1500 is ticking bad. Found out the timing chain is a bit loose. Could this be the cause?
  8. I
    4.7 timing chain tensioner replacement
    Hello Folks, Newbie here. Have a lead on, and am considering the purchase of, a Ram 1500 with a 4.7 liter engine that is making timing chain noise and giving an occasional code for the camshaft. Thinking it might be the timing chain and/or tensioners. I was wondering if this is something...
