tire load rating
  1. J
    H load rated tire for RAM 5500
    OEM from factory is G load rated for 22 RAM 5500. H rating gives about 500 pounds additional load but at 120 psi instead of 110 psi for G. The tire has 2 additional ply's, 14 vs 16. Any one have any experience with H rated tires ? What is the trade off ?
  2. Y
    Towing with RAM 1500 (Tire Load Rating)
    HI There, I'm new in to towing so I'd like to make sure I'd be doing it safely. My truck is a RAM 1500 V8 HEMI with 3.55 axel ratio, and I'm planning to tow a 7000Lb (GWVR) RV with a 670Lb hitch weight. I will use a Curt WDH w/Sway Control. Unfortunately my payload is only 1245Lb so by...
