wont start
  1. B
    Ram 2015 1500 not cranking or starting
    Ram 1500 started having weird electrical problems, such as making a weird ringing noise when starting and turning the car off until the cpu shuts off or ten plus seconds go by. Then the driver side window buttons for the front seat stopped working, but can roll it down from the passenger side...
  2. Twduck1972
    2015 6.4 H 5500 wont turn over HELP
    Alright guys, I have a 2015 5500 with a 6.4 Heimi. I Went out in the morning to start it and leave it clicked once but did not turn over. I checked the battery the battery is at 12.6 amps I checked the fuzes, the coil wires they too are at 12.6 amps. I went and replaced the starter thinking...
  3. B
    Push Button doesn’t work 2014 Ram
    Hey guys, hoping someone can point me in the right direction. Make it short, truck worked fine, parked it and left it for a week. Went to start it and nothing! No response from the push start button. It wouldn’t even light up. Everything else worked, key fob, locks, lights, and when you pressed...
  4. J
    Screwdriver Key 04 Hemi
    Some idiot tried to steal my truck with a screwdriver. Locksmiths wouldn't touch it so I had it towed to the dealership for repairs. 11 months go by with excuses like waiting for parts and short manpower I had it towed back home. The dealer did put a new immobilizer in the truck but the most...
  5. E
    engine wont start 06 1500 hemi
    So yesterday after starting it the engine stoped after moving like 2 meters so checked the battery and everything and see that one of the copper terminals on the battery broke i tried stick the cables to the main terminal with locking pliers but nothing the cluster and everything works fine also...
  6. Leemoney
    2016 WON'T START
    This issue started when i tried to crank it last week. Dash lnstruments bliking, won't start and said truck was not in park, rather in reverse. I was told it might be the original batteries, so last nite i installed 2 new batteries. Gt in the truck and still wont start, says its in reverse...
  7. D
    Electrical? Software? I can't figure it out
    2015 Ram Quad Cab. Bought brand new. Over the last 2 - 3 months my remote start wont work, neither will RKE and when I get in the truck the start button wont work for 5 to 10 minutes. After which I will get the double click from the instrument panel and the ring around the start button will...
  8. S
    help needed
    hello all and want to say thanks for the add to the forum. i have a 02 Dodge Ram v6 it was given to me for some money that was owed to me, i thought it was locked up but i put a shot WD40 in each spark plug opening and 2 days later it turned over. the problem is it turns over but wont start...
rockyj69
