03 slow speed overheating
poorman
I have a 2003 Dodge Ram 1500 Quad Cab that will over heat when going slow in town OR going up a big long hill, but will drive all day long at 70mph on flat ground, and run perfect temp. But today it overheated going DOWN the mountain :(
any ideas whats wrong with it? this is the only problem i have with it everything else works perfect...
thanks
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Welcome to the forum, hows your coolent level looking? Be careful driving that once it gets hot 4.7s can warp the heads just enough to cause a coolent issue.
P
poorman
coolant level is full, and under most circumstances it runs just a tad under 1/2 all the time,
thanks
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Have you checked the rad itself? On your body style the rad and overflow tank should be seperate.
05singlecabHEMI
Lilburn,GA
Maybe check any leaks around the water pump? Have any mods on it at all?
P
poorman
thanks, no leaks anywhere, is there a way to see into the radiator on this one? ive never seen it, and no mods all stock...
TheSatinPumpkin
Robles Junction/Three Points AZ
2004 Dodge Ram
5.7L
It understandable that the temp would be okay at highway speeds since there is plenty of air moving around. Its mostly go to go traffic and idle in which the fan will need to be used.
Great suggestions posted but also check to make sure there are no air pockets so maybe do the "burp method".
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
The clutch fan could be going out also good idea Daniel.
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
i'd make sure one of your coolant lines isn't plugged with crap.
Or the radiator for that matter.
If you don't see any leaks on the ground, I'd take a real good look to make sure you're not burning it.
smykowski
Pacific, MO
2010 SLT
6.7L Cummins
very good possibility, a stat that doesn't open will make for an unhappy engine.
LB3711
Trumbull, CT
3.6L V6
Cheapest and easiest fix
Sent from my AT&T iPhone 4.
