04 / 5.7 VS 09 /5.7 Rods and Pistons ?
Tony8327
Cowarts , Alabama2
I have a 04 / 5.7 Ram that I am rebuilding.
I have a set of 09 / 5.7 rods and pistons that has low mileage on them . Holding them side by side I can't see any difference , the rods and pistons look to be the same size . But there is one difference that does concern me , it is the oil rings . it is the Same set up on both , but the oil rings on the 09 is almost half the width of the 04 rings . It would save me a few bucks if this swap will work , but I need advise on this , any help will be greatly appreciated, Thanks !
BrianandChrissy
Buffalo NY
2016 big horn crew cab
5.7 hemi, vararam CAI
You need to take a set of calipers and verify all specs of each piston. I'd be willing to bet they are different.
Sent from my LGMP450 using Tapatalk
Tony8327
Tony8327
Cowarts , Alabama2
Will do , thanks ! If by chance they do match up , do you think the difference in the oil rings would matter ? Thank you again for your advise .
BrianandChrissy
Buffalo NY
It may, depending on certain aspects of the older 5.7. Maybe someone else could help us out here, as I've always bought new.
southalum
