04 RAM 1500 4.7l Oxygen Sensor heater circuit performance
David Mummery Jr
Fernandina Beach (Amelia Island), FL
4.7L vin 'N'
Hey Guys, I am the FNG today! Need some expert opinions...
The Truck (my baby):
2004 Dodge RAM 1500 SLT Quad Cab 4x4 4.7l vin 'N' (NGC) (California).
Repair:
*Replaced all 4 O2 sensors with new NGK OEM units.
Reason:
the old ones were lazy and not working properly, fouled, and the fuel economy was toast at 6 MPG. Verified with scan tool diagnostics. It is now 13.8 MPG on the overhead console.
Problem:
I have an odd problem I want to bring to the experts here.
They worked perfectly for the first 2 weeks. Fuel economy was a little over 2x what it was. The guy I bought the truck from with 212,000 miles had factory installed shocks still. Yes, and he worked on the RAM line when the truck was built. I am a pretty good mechanic. I have a Launch X431 V+, and an Autel MS906BT dealer level scanners. I am actually a certified electronic tech, so I am better with the computers and electronics than something like rebuilding a transmission. I have rebuilt many engines in my years.
Note:
I have a Hantek 8 Channel scope and a PICO 2 channel lab scope with all the probes, back probes, etc. etc. I did check the new sensors just to make sure they didn't go bad for some reason. They are all perfect.
First Issue:
All of a sudden I get all 4 O2 sensor codes P0135, etc saying the heater circuit performance was bad. Checked grounds and found lost grounds. I repaired the grounds at their termination point G107 right passenger fender. That fixed both upstream sensors and no codes on them for several trips. I also verified good ground at the O2 harness to sensor connector for all 4.
However, both downstream O2 sensors popped the same codes up again after one trip. I was monitoring them on the Launch and the heater circuit was pegged at 100% all the time. I checked the voltage to the heater. Being it is Pulse Width Modulated, I had to activate the heaters independently through the scan tool.
***The voltage I get is 7.74vdc. Not battery voltage.*** Unfortunately, the factory manual didn't indicate a voltage, and neither AllData nor Mitchell's indicated it.
***Is that voltage correct due to it being PWM. I am pretty sure I should be getting 'battery voltage when I activate the heater for testing the voltage on the heater circuit. Am I missing the plot here?***
Second sort of issue:
In the TIPM, there is a fuse and relay socket for "Downstream O2 Sensors". Under the cover, it says O2 Sens. (8.0L Only) for the relay and fuse. There is a fuse in there and the relay socket has wires and terminals in it. There is no relay. My general rule is to keep to what is in the vehicle and not the manuals which may not have been updated. Also, since they worked previously without the relay, I am sure the TIPM cover is correct and it is for (8.0l only).
So, I go check AllData and Mitchell's to see what they say about it. Both say (California) and nothing about (8.0l only). WTF? This truck is a California emission vehicle. Does it need the relay or not? Right now I say it does not.
My current plan is to test resistance across the heater control wire from the PCM and ensure it is under .5ᾨ. If they are good, then It is a PCM issue and I will be swapping out the PCM. Here is why I am thinking the PCM is bad:
When in idle the B2/S2 O2 sensor long term fuel trim is pegged at 12,000%! Yes that is an actual number on the Launch. The Autel is 99%. When I step it up just off idle it drops to the correct ranges.
BTW, the new sensors are running very close to zero when you add long term and short term fuel trim together. The truck runs perfect as well. I think the PCM has a fault, but am going to finish the diagnostics first on the wires and connectors.
Since I am getting RIDICULOUS LTFT on B2/S2 at idle on both scan tools, I think that the PCM has a fault. Otherwise, I have never heard of numbers like 12,000% or even 99%. I believe the max is 25%.
Well, throw some darts at me or let me know what you think about this. It is one of those things where you wake up in the middle of the night and wonder if you diagnosed everything correctly and WTH is that ridiculous number coming from! Grrrr!
Thanks in advance for your input.
Dave
Eray
Fort worth
Im having same problem but with both o2 on bank one im thinking short mine maxed out at 32% moved harness while changing valve cover and seemed to help so there is a short i ges on top of transmission part of the harness did you find a fix i also get a random misfire everyonce in awhile if i just start and go if i let her warm up for a minute its fine iv checked compression, fuel pressure and changed all coils and plugs
