07 1500 st shock torque spec
Jack Davis
Fl
i know the rear shocks are 100 ft lbs but im not sure about the front bolts on the bottom i have seen 34 ft lbs and if im not mistaken the nut on top of the shock gets tighten to the point the rubber bulges out a bit and is the same size as the washers
Steve58
