08 manual transmission shifter knob removal
Patrik
Lexington NC
6 cylinder
Does anyone know how to remove the shifter knob on an 08 ram 1500?
Gear Jammer
Yacolt WA
Cummins
On the 2500's you pop off the part of the knob with the shift pattern on it, once it's off there is a nut you loosen. I don't know if 1500's are the same, but its worth a shot.
3pedals
Central Valley
What gear jammer said…pop cover with shift pattern, remove nut, unscrew knob
Recommend the Core short shifter if you’re looking for such a thing. Have had mine for well over 200k miles (with supplied hurst knob) and it’s still working great.
P
Patrik
Lexington NC
6 cylinder
It's a floor shifter for a red cab 3.7 St trim model 2 wheel dr . I tried popping the top where the gear pattern is and no luck
phorrestphire
