1994 B350 Van Welded in a new battery box, now no spark. What did I burn out ?
monoshock
1994 B-350 Dodge high top van with 360/5.9. I welded in a new battery box to replace the rusted out one. I removed the battery and placed the all cables out of the way. Now no spark at the spark plug wires. I was using a old stick welder. I may have touched the hot cable going to the accessory's, not the hot cable to the starter, but I'm not sure because I had my helmet on and when I stopped welding, this cable had come loose and was close to where I was welding. Help, what expensive part did I burn out ?
Ram-engineer
hemi 6.4
You checked all fuses I'm hoping you missed one. Other wise can be as bad the Ecu
Sent from my SM-N930V using Tapatalk
M
monoshock
I checked all the fuses with a test light, all of them were good.
