1998 Blinker Hazard issues
NeedLotsOfHelp
AL
SomethingThatNeedsGas
I have no clue what I am doing but this makes no sense. Whenever I turn the hazards on, I am getting both sides in the back to light up fine. If I try to simply turn on the left/right signal, neither work.
I can hear the relay when the hazards are on and I have swapped out the fuses in the cab and under the hood that pertained to the signal/hazards though without another relay available, I have not swapped that.
I guess I was under the assumption that the hazards are simply just both blinkers but apparently this is not the case. Is there anything someone can point me to that could get me off on the right path ?
joshhhh
