1998 Dodge Ram 1500 Project
MCIntoDarkness
Mississippi
3.9L Magnum V6
I thought about doing the green but I figured red would look better because red truck. Doing the red dash light isn't that hard of a swap either.
I started to do blue, but went with green because I'm OCD and I wanted the floor to match the dash lights. :p
dapepper9
Iowa/Nebraska Border
5.9L V8
Woo! Nice job man. I got the same kit a year and a half ago and love it. I used the add-a-fuze to tie mine into the radio. Crank the tunes and play with the adjustment on the box. Tons of fun. Im so used to move i forget they're going sometimes lol. Girls love it at night too :naughty:
#moodlighting
Merc225hp
NA
truck
gas
#moodlighting
thats not what i used to call them lol.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
That's why I did mine, because these trucks are so dark. The only source of light at night is the dash, which is not much. And, the install isn't all that hard, takes about an hour, and you only need basic tools such as wire strippers, a screwdriver, some side-snips for cutting zip-ties, and a wrench to get your negative battery cable undone. You can either zip tie the tubes up, use the supplied 3M foam adhesive pads, or screw the brackets into a solid surface.
Brandon
Cool. And where'd you get em from? If they're cheap enough I might put some in my girl's car because I know she'd like em.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
LOL ****-lighting?
My boss told me how back when he was a teenager, guys would dip dome light bulbs in different colored paint and keep multiple in the glove box depending on the....situation....:naughty:
Said the blue made em feel not as nekkid. Used red to **** em off. :roflsquared:
Merc225hp
NA
truck
gas
No not that more like F*** lights. If I remember we had black lights in the trucks. But i am not sure you can even get those bulbs anymore.
dodge dude94
Millennial Boomer
East Texas
1998 Ram 1500
5.9 Magnum
lol you can still get black lights but I don't know if you can get them small enough to put in a truck unless you were using 18in fluorescent with an inverter.
dapepper9
5.9L V8
They're great. I love mine and I'm sure you will too. They have a 7 color kit as well but it's not as good. My bro got it and it wasn't as good
BlackMagnum2000
Locust Grove, GA
5.9 Magnum
Not to **** on y'all thinking the $30 is a good deal but I spent $1.25 on mine and had LEDs to spare......
tommyboi87
houma louisiana
5.2 Magnum
For 1998
Ash Tray Light Bulb 161
Auto Trans Indicator Light Bulb PC74
Back Up Light Bulb 1156
Center High Mount Stop Light Bulb 921
Check Engine Light Bulb PC74
Cornering Light Bulb 3157
Courtesy Light Bulb 194
Dome Light Bulb 579
Engine Compartment Light Bulb 561
Glove Box Light Bulb 1891
Headlight Bulb High Beam and Low Beam 9004
High Beam Indicator Light Bulb PC194
Ignition Light 1445
Map Light Bulb 212-2
Parking Brake Indicator Light Bulb PC194
Seat Belt Light Bulb PC74
Side Marker Light Bulb Front 3157A
Side Marker Light Bulb Rear 194
Trunk or Cargo Area Light 921
Turn Signal Indicator Light Bulb PC194
Turn Signal Light Bulb Front 3157A
Fog Light Bulb Front 893
Parking Light Bulb 3157A
Is that also for 99?
Sent from my SAMSUNG-SM-G925A using Tapatalk
dapepper9
5.9L V8
Should be. If not most are. Go to superbrightleds.com and use their bulb finding tool to cross reference
