DefiantRage
- Joined
- Nov 16, 2019
- Posts
- 10
- Reaction score
- 1
- Location
- Calgary alberta
- Ram Year
- 2003
- Engine
- 5.7 hemi
I am a tow truck driver who recently picked up a 2003 ram 1500 5.7 hemi quad cab 4x4 345,000km. The previous owner released its ownership for free to the company because it lost oil pressure, so he pulled over instantly and shut the truck off. I picked it up for 200 from my boss and changed the oil pressure sensor and it runs great! I see people posting these for sale for 3-4k and thought, if I rebuild the engine, transmission and do some upgrades to the suspension, costing 3-4k doing the work myself and only worrying about parts, I would be able to have this truck last me for quite a few years if treated properly.
So here is my plan!
I want to rebuild my 2003 5.7 hemi from the ground up, starting with a full high quality rebuild kit. I also want to upgrade my heads to the eagle style head with MDs delete and upgraded valve springs. I will have to get a custom extra thick gasket to have the heads sit properly with enough valve clearance. I also want to install a new cam shaft that will increase performance, as well as efficiency in general with possible towing and 4x4 in mind. I want to replace the coil packs with newer 2009+ to match the eagle heads. I also want a matching intake manifold that will fit on my 2003 block. I want to slap a set of headers on the exhaust, since the manifold is already leaking, while possible doing a cat delete and pipe it out in front of the rear tire. I also plan on swapping out the old pcm/ecu to a newer 2005 model since it offers more custom tuning options with most tuners on the market. I want to also add a ported 90mm throttle body and cold air intake.
On top of that, I want to go through the suspension and replace and repair parts that need more than a bushing swap. I want to clean it all up and paint it nicely to help prevent rust and stuff. I want to be able to take this on some trails once and a while but still be functional as a daily driver/work truck for pulling a trailer. What kind of suspension upgrades or mods are worth investing in? I was looking at a full set of air shocks with a compressor for a decent price from a 2014 model and was curious if that could be made to work or not. I was also thinking of just getting 2.5" spacers for the front and a little 1.5" lift for the back just to add that little bit of clearance.
I am also planning on buying a monster rebuild kit for my 545rfe transmission, and installing it to the best of my ability. I want to make sure the engine and tranny are both in new condition and are the least likely to be an issue anytime soon with regular maintenance. Is there anything not included in the rebuild kit I should also order, to improve the integrity of my transmission? Any weak parts that have reinforced and newer replacements?
The end product I am looking for, is a powerful and strong built truck with a 93 octane tune running premium synthetic oil and it won't leave me on the side of the road anytime soon. I don't want to be punching it from light to light, but it's nice to know I have the power, when and where I need it.
My biggest question to the community is, does this seem feasible and worth while? Any kind of input would be greatly appreciated. Money shouldn't be too much of an issue in the next couple months, so I am just trying to explore my options and get a solid game plan down before I go buying stuff that won't work or is a total waste of time and money. If you made it this far I applaud you my friend and hope to hear from ya soon.
Sent from my SM-A530W using Tapatalk
So here is my plan!
