2005 dodge 3500 5.9 ECM problems
Bluecollar13
Rogersville, TN
Will alpha obd2 flash my ecm on my 2005 dodge 3500 5.9 Cummins auto truck ? Does anybody know of any other programs or applications I could use to do such ? Also my truck has a late model 2004 ecm on it I’m assuming it’s from the factory. I bought the truck the guy told me it needed to be flashed that he couldn’t find no one to do it so here I am trying to figure it out. I’m new to the diesel world so any thing would help. I also have a 2006 ecm that came with the truck but still won’t start it. The truck also has a buzzing sound coming from the injection pump after you turn the key off anything about that would help as well.
mtnrider
Georgia
AlfaOBD is not a tuner, it cannot flash a ECM. It's capability is also very limited on the older trucks like yours.
I wish you the best of luck, unfortunetly when someone sells something they could not fix it usually has a lot more issues then they ackowledge. You probably are going to have your hands full.
You might also want to try the diesel specific forums, this is mostly a gas focued forum.
HemiLonestar
Navy Badge Coast Guard
MD
AOBD is CAN only, you have PCI. It has zero capability. Don't try to use the newer PCM in the older truck. 06+ is CAN, 02-05 is PCI.
rockyj69
