2004 DODGE 1500 3.7
Preacher Dave
Monroe City Missouri
have or need help with wiring on 2004 dodge 1500 3.7 st. have 12v to injectors... engine cranks but no start. if you spray c
arb clean or gas into throttle body engine starts immediately or fairly quickly. have had at a garage for 6 months and no help. am going after it and see if i can't take care of it myself. he replaced the ecm but it supposedly got fried. i had replaced the fuel pump 60 lbs pres. on fuel rail, replaced cam and crank sensors. i'm assuming either a bad ground or broken wire, but honestly don't know. that is why i'm here asking for real help. please!!!!!
david wilson sr., pastor warren christian church, monroe city, missouri
Edited by an admin.
work truck ram
You do or do not have 12V+ at the fuel rail? Ign on there should be steady 12V+. Running there is a neg pulse sent from the ECM. No power is fuse or bad connection. Fuse boxes are a known issue on these rams if they get weather in them. Jump a fused hotwire to the injectors to determine if the neg pulse is good.
Neg pulse signal is determined by cam sensor. Cam sensor is on the passengers head, front lower side. Tone ring can be damaged that it reads. Can pull the valve cover to inspect.
