2010 dodge ram 1500 trx 4wd vibration
Brian Dickey
st.louis,mo
New tires that were all road forced on stock rims. Hit about 65-70 mph truck vibrates. Had tires rebalanced same issue. I was told maybe the rear rotor ? Any suggestions
ilovemyramlaremie
Moravia NY
Where are you feeling the vibration, steering wheel, seat? If it on the steering wheel, it’s most definitely a rotating issue. Could also be driveshaft/u joint related, or suspension if it’s in the rear
B
Brian Dickey
st.louis,mo
Mainly in the seats, I gonna try to install new rotors and pads to see if that will fix it.
Kmiko
