Grams
- Oct 4, 2024
- 1,189
- 1,920
- Location
- Texas
- 2024 & 2015
- 6.7 Cummins & 5.7 Hemi
The day I bought this ‘15 Ram 1500 …I Test drove this truck with the sales-person and found a vigorous front-end “shake’ above 60 mph. Pulled into the local Firestone Auto Center. (This is all in a town 100 miles from my home.)
I asked for a Front end inspected by Firestone …. Good condition was pronounced…but all 4 tires condemned with broken belts.
Bought 4 new Firestone Destination LE3 tires. Roadhazard and Forever Balance also purchased. $1200.
Drove it back to the selling dealer and bought the truck, …but noticed it still had a tire-balance issue on the rears at 65 mph.
Took it to a different Firestone Auto Center closer to home… (about 25 miles away). They replaced the rt-rear tire due to slipped-belt, and re-balanced both rears.
With rears in better shape..the Fronts are now noticeably vibrating from 65 to 70 mph…. So took it back next day to have fronts re-balanced. Also asked for a front-end alignment. (They offer an alignment for $150…. or a “Lifetime Alignment) for $200. I paid for the “Lifetime”.
They pointed out the only thing found out of spec was Toe-In…which they adjusted….and informed me that no caster/camber is adjustable on this truck. No mention of any other issue, and they re-balanced the front tires.
Took it back next day again for Front still having a “mild” vibration at 65 mph.
Now Firestone claims upper and lower control arms, ball joints, and tire-rod-ends need to be replaced.
I told them the FIRST Firestone shop had inspected the front end and found it “in good conditon”…and that THIS Firestone shop had aligned this truck only YESTERDAY….and only mentioned the Toe-IN needing adjustment….. NO MENTION of “tie rod ends” or any other issue with the front-end.
So I called the FIRST Firestone 100 miles away and conversed with and reminded the manager, “Ben”, …that He and His Shop had inspected this front end when selling me tires and found it in “good condition”….and informed him of the second Firestone shop who after 3 visits now condemns the front end.
“What is going on here?”, I asked.
He suggested I take it to a THIRD Firestone shop which is equipped to “Road Force” test the tires…. and that if there proves to BE a “front end rebuild” necessary….that HE would “Make it right” for me at His shop. (No idea what that means.)
Takin it to Firestone number-THREE tomorrow ..to have them road-force checked. Vibration on front felt any speed above 35 mph, but I have a difficult time believing this is due to worn control arms, ball joints, and tie-rods. (Although I’m not a novice and am familiar with front end suspensions and the reputation of Dodge ball joints. I have looked under the vehicle and it Does have 181K miles on it… but it doesn’t display loose or worn bushings, etc.)
We’ll see what transpires tomorrow.
