riggz
Forgot my volt meter at the house and having trouble finding the wire colors for the front signal/park lamps. Need to install a resistor on the fronts for the LED switchbacks.
I've got all LEDs and only installed the 3ohm resistors on the rears as that seemed to work for well over a year. Then all of a sudden I started getting a right rear lamp out waraning. I thought maybe the resistor went bad so I swapped it out. No dice. So I added one to the front using what I thought was the correct wires (black/green & white/tan) now I'm getting a warning that BOTH are out.....
