ok well Ive pulled a 8,000lbs hitch trailer with 12 harleys roughly (300-400lbs a piece) in it with swaybars and had no problem. im not trying to say its not possible. yes it can get hectic at times but a goose neck pulls ten times better. This is with my 2011 powerwagon. This truck will pull ten times better v.s. the ave because you have solid front axle and you have larger running gear and the more you weigh. The 4.56 also make it ten times better to tow even with my 35's. Im not saying the truck can not handle it im just saying I beleive it is safer and better on the truck and handling as far as using a goose neck. I use both but if im pulling over 8,000 i like to use my goose neck trailer just because it rides a lot better.
