Help Support Ram Forum by donating:
2012 Ram 1500 exhaust pipe size?
Discussion in 'Engine & Performance' started by h20man, Apr 17, 2012.
Sponsored By: Moe's Performance
  1. h20man
    h20man Junior Member
    Apr 8, 2012
    Ram Year:
    Engine:
    Do all 2012 Ram 1500 with single in dual out have the same size pipes (3 in, 2.5 dual out)? I took a Magnaflow 14 inch #12198 to a shop today to have installed. The guy told me the muffler doesn't line up right, the pipes going out are 2 1/4 inches and it would taken quit a bit of modification to have it fit. I had him put the original muffler back on and think I will take it to a shop that I have used before that I have confidence in. Did I order the right muffler? I just want the old one out and the new one welded in, I realize some pipe will be needed to compensate for size. Thanks
  2. quietpeen
    quietpeen Administrator Staff Member Administrator
    24,895
    3,656
    Jul 14, 2010
    Ram Year:
    2019 Jeep Wrangler Unlimited Rubicon
    Engine:
    Pentastar V6
    Welcome to RF. Looks to me like you got the right muffler. Definitely try the other shop that you have more confidence in.
  3. h20man
    Apr 8, 2012
    Ram Year:
    Engine:
    Thanks for the welcome, I'm on my 2nd Ram. Had a 2009 and just recently got the 12'. Yeah I assume the shop should just be able to weld the new one on with a little added pipe coming out of the dual outlets. This guy today had no freaking clue. Told me that Ram had a whole system that could be clamped on, I knew enough to just tell him to put my muffler back on and walk out.
  4. WhiteExpress
    WhiteExpress Senior Member
    17,880
    3,136
    Sep 8, 2011
    Carlsbad, NM
    Ram Year:
    Engine:
    3.5 EcoBoost
    You can indeed purchase a mufflex that will replace the factory muffler, all bolt in.
    I don't know that there is really a large advantage to doing so.
    When I measured the tailpipes, I had 2.5". I really doubt yours to be different.
  5. h20man
    Apr 8, 2012
    Ram Year:
    Engine:
    Yeah i have the Magnaflow muffler already that I believe is the same one used in the Mufflex kit. I just want the muffler welded in place of the old one and want to keep the stock pipes and tips. Have an appointment somewhere on Thursday. I am correct in assuming that all is needed is extra pipe to compensate for the shorter muffler? Seems like a simple job for a good exhaust guy.
  6. Bigdaddy
    Bigdaddy Senior Member
    2,176
    339
    Dec 13, 2011
    Ram Year:
    2018 3500
    Engine:
    6.7L Diesel Cummins
    Yep! yes it is plain and simple I had the guy do the same on mines, well almost.
  7. Bigdaddy
    2,176
    339
    Dec 13, 2011
    Ram Year:
    2018 3500
    Engine:
    6.7L Diesel Cummins
    Welcome to RF.
  8. GhostRam94
    GhostRam94 Senior Member
    25
    6,486
    155
    Feb 28, 2012
    Hunstville, Texas
    Ram Year:
    2009 Laramie CC
    Engine:
    I had the same issue with my guy, just told him to do it and stfu, 20 minutes later, I hear a low roar and da wittle 287 had been bombed:D
  9. h20man
    Apr 8, 2012
    Ram Year:
    Engine:
    Well suprisingly after having the new Magnaflow muffler installed I found out that indeed the stock muffler was 3" in and 2.25"dual out. I still have the stock muffler in the garage. The guy had no problem with the install and weld. Love the sound now with the Magnaflow, drone isn't too bad. The drone isn't nearly as bad as the Borla I had on my 09.
  10. jacsyl94
    jacsyl94 Senior Member
    179
    Oct 20, 2011
    Corpus Christi, TX
    Ram Year:
    Engine:
    Music to the ears..nice..
Share This Page
