2013 Ram 1500 gauge cluster
Michael Perkowski
2013 Ram 1500 Laramie Longhorn
I have a 2013 Ram 1500 Laramie Longhorn, and had my evic center lights start flickering, so I decided to get a different cluster, which is from a 2014 Laramie Longhorn, and see if that would fix the flickering backlights, well it did, it all works fine except for one thing, the TPMS won't sense the tire pressures, and the idiot light stays on all the time. I was told by someone that the 2013 Ram 1500 used a different frequency than the 2014 Ram 1500 and that is why it won't pick up the sensors and reset. Does anyone know how to fix this, would I be able to buy a TPMS module and sensors for a 2014 Ram 1500 and install them and this would fix the issue, or is there a different way to do this, I really like the TPMS feature, and would like it to work, so please help me, thank you, Mike.
stimpy433
IOWA
You just need to replace the sensors in your tires with ones for a 2014 truck....
Michael Perkowski
Michael Perkowski
So I don't have to change the TPMS module, the new sensors will mate with it?
jhicks1983
