2013 Ram Express remote start
Jared4.7
Olathe, KS
2017 Bighorn CC
Can you guys help me with figuring out the correct remote start kit for my truck?? Ive seen too many conflicting numbers and want to make sure I get the right one. Thanks!
Sent from my SPH-L710 using Tapatalk
AllMoparParts.com
- Benny
Supporting Member Supporting Vendor
All
All
I would need your VIN to see if the available one is applicable.
Thanks,
Benny
Jared4.7
Jared4.7
Olathe, KS
2017 Bighorn CC
Sorry for my super slow reply. I just got a 14, how about this VIN 1C6RR7KT5ES201991.
AllMoparParts.com
- Benny
All
All
Sportznut
2019 Laramie
Anyone installed this? How much did your dealer charge for activation?
edward1225
Hey guy i have a question about this oem kit i see the install instruction that where posted i just put this kit on my truck last week i did the install seems pretty simple took me about 3 hours in the instructions it say if your truck is equipped with the factory harness just plug it in i took it to the dealer programmed the key know i get an error on the display and it says remote start cancelled hood open any idea if the harness on the truck needs to be plugged in anywhere in the truck the directions dosent say or if you need to add a fuse if anyone could help me that would be great also i checked the harness that gets plugged to the hood latch and i have no power in that harness
BLKMAGIC
Edward, you need to have the option code added by the dealer, nothing will work until that is completed.
jwheeler
Washington
Whatever the hourly rate is. They should do it for an hour. Usually about 100
AllMoparParts.com
- Benny
All
All
Correct, as mentioned the remote start sales code needs to be flashed in, Not just the key programmed.
-Benny
edward1225
thank you for the help how do i know if they did that or not when i took it to the dealer they had no idea what to do i had to show them to unplug the old module and plug the new one in now on my harness that comes from the truck i checked it out i only get a ground. the sensor for the hood latch weather the sensor pin is pushed or not pushed i get nothing on the volt meter. there telling me the sensor on the hood latch is bad.
AllMoparParts.com
- Benny
All
All
I would honestly seek another dealer who is more familiar with the accessory remote start kits before determining any components are bad.
-Benny
frenzy_6900
