2014 2500 Pushbutton & Mirror Parts
Beemer533
CNY
2014 Big Horn 2500
Hi Benny, I'm looking to upgrade my 2014 2500 Big Horn for pushbutton start, proximity entry as well as power folding tow mirrors.
VIN: 3C6UR5DJ6EG114019
For the pushbutton start I want to confirm these are the correct parts (mostly not sure about the Hub receiver as there seem to be several versions)
Ignition Switch 6CK46DX9AC
Passive Entry Antenna-Front/rear cab 56046958AA
Passive Entry Antenna-Doors 56046957AA
Hub Receiver 68213674AG
For the handles, I currently have the chrome ones which I'd like to switch out to all white, but I can't seem to find my paint code PW7.
I think these handles might work but I'm not sure if the GW7 paint code is the same?
Exterior Door Handle, Left rear 1GH19GW7AF
Exterior Door Handle, Right rear 1GH18GW7AF
Exterior Door Handle, Left front 1UJ81GW7AI
Exterior Door Handle, Right front 1UJ86GW7AI
I also need the part numbers for the front door modules to add power folding tow mirrors.
I'll probably want to buy everything other than the handles right now as it will be a bit before I get around to adding them.
Thanks!
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hi,
Use Hub 68213679AH , All else looks good.
Your door handle part numbers are perfect!
For the door modules use 68286791AA & 68286790AA
I will PM you a code to use,
- Benny
Beemer533
Beemer533
CNY
2014 Big Horn 2500
Hi Benny, I put in the order last week for most of the parts above, but I was just informed that there is a national back order for the 68213679AH hub.
Do you know if there is an alternative part I can use or should I start looking for a used one if that is the only PN that will work for me.
Thanks!
AllMoparParts.com
- Benny
Preferred Vendor
All
All
Hi,
I would not be comfortable recommending any other one as I do not know what negatives there may be. For example the one with air suspension option 68213677AH.
Yours should take about 30 days to get from the info I have as of today.
Please let me know if you have any other questions.
Thanks,
-Benny
