2014 Ram 1500 factory brake controller help....
medicman91681
Purchased the install kit for my ram. Installation was very straight forward. After installation I took my truck to the dealership and had the system programmed, after the programming was complete it shows in all of the right places but no matter what I do it shows “no trailer connected” and when I pull the trailer settings on the EVIC the slide switch does nothing like changing the gain or anything. Does anyone have any other ideas of what I could check? The dealership wanted a ridiculous amount to troubleshoot it.
22hemi13
Tucson AZ
2014 2500 4x4
You have a trailer hooked up right :hmm:
medicman91681
medicman91681
Yes, the slide switch is lit up when the headlights come on so I know it’s getting power I’m just not sure where to go next.
AFMoulton
Nuevo Mexico
Might have got the wrong controller part number. They are different between 13-14,15,16,17-18. 4 different part numbers. ****** but might want to double check the right module was installed.
2018 2500 6.4 4x4 4.10 Amsoil SS 0w-40, Softopper
Black Rhino Armory 18x9 +12mm
Cooper Stt MAXX LT295/70R18
2016 Durango 5.7 AWD 3.07 Amsoil SS 5W-30
1996 Nissan Altima 2.4 Amsoil SS 5W-30
IxsharpxI
Missouri
Im actually getting ready to tackle this on another 2014 ram 1500 sport can anyone confirm that 82213474AB (or ive found the non AB version) is the correct part number for 2014?
stevenP
northern Indiana
2022 2500 Longhorn
6.7L Cummins
Another stupid question, your trailer has electric brakes right? In the radio setting for the FBC, you need to see the different settings (light electric, heavy electric, hydraulic over electric) on the brake style your connected to. You could also have a flaky pwr connection or ground that would cause this same issue.
With your trailer connected check voltage between pins 1....ground, and 2 brake voltage. Ram FBC's are a pulsed wave DC type. You would be lucky seeing like 7-8 volts maxed out for the brakes. I installed a tekonsha P3, and bypassed my factory RAM controller. Night and day difference in performance.
